Tuning the Alpine PXA-H800 DSP
I tried. Go back and read. Btw...get off my *******.
---------- Post added at 12:21 AM ---------- Previous post was at 12:20 AM ----------
Right here... //content.invisioncic.com/y282845/emoticons/popcorn.gif.32dd9e22fd77e77bc3c907062768fcd2.gif
It doesn't matter if you tried. All that's seen now is that you are a pest trying to make things worse.
You sure are on my n u t s a c k tonight....
Help John out then. But your more focused on me instead. Talk about calling the kettle black.
BoominTahoe is on my s h i t list for two distinct documented facts: he lies and said I called anyone here an amateur when I never did and he does not believe I have a degree in Electrical Engineering even after I scanned and posted a pic of my diploma! Although he also recently gave me some good car audio information.
John Kuthe...
John Kuthe...
Get over it.
I got some good information her within this thread. Thank you very much.
I'm thinking if I have to do a bunch of rewiring I may just go full active EQ and use the 8 outputs of both amps to power the four 6x9s on the PDX amp and the PDRs outputs will be to the two 5.25" and their associated tweeters. Subwoofer still off the PDX just not under DSP control, at least directly. Does that sound like a feasible plan? Does to me! With the DSP I should be able to control each driver separately except the sub. Will that work? I know the one or two outputs from the DSP say they are for subwoofers, but can I use them for full range as well?
John Kuthe...
I'm thinking if I have to do a bunch of rewiring I may just go full active EQ and use the 8 outputs of both amps to power the four 6x9s on the PDX amp and the PDRs outputs will be to the two 5.25" and their associated tweeters. Subwoofer still off the PDX just not under DSP control, at least directly. Does that sold like a feasible plan? Does to me! With the DSP I should be able to control each driver separately except the sub. Will that work? I know the one or two outputs from the DSP say they are for subwoofers, but can I use them for full range as well?
John Kuthe...
Keep asking questions. Just remember it's not necessarily what you say but how you say it.
You completely didn't answer my car audio question in favor of meretricious piffle as my electrical engineering power lab instructor called it.
John Kuthe...
John Kuthe...
Sorry I must of missed it.
I see a lot of papermaker spelling and grammatical errors. My brain skips over.
JohnKuthe
JohnKuthe
Missouri
JohnKuthe
