Tuning a mono amp with 2 channels that are wired parallel in the amp?
  • 1
Justinw303
[Space for Rent]
I will be tuning a Phoenix Gold Xenon 400 watt 1-4 ohm mono amp using a multimeter. My sub setup will be two 8" 4 ohm DVC RE subs from RE Audio. Each sub will be wired in series, so that I am connecting two 8 ohm loads in each "channel", which I believe are wired in parallel for a final load of 4 ohm.
So when I'm calculating the voltage I should see on the multimeter, measuring at one of the sub output channels, should I use the impedance of the sub (8 ohm) and the wattage I want to send it (200), or use the impedance that the amp will see (4 ohm) with the wattage(200)?
SQ is subjective. If you're looking for the flattest possible response curve, usually sealed will give you that in a car. Porting is more...
Justinw303
[Space for Rent]
Justinw303
Silver Spring, MD
Justinw303
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
