Tundra DD 9515 build
That's good to know about the amp. Setup is looking good too, you running it at 14 or 16 volt?
I have the batts wired to 12V since this is just a daily setup.
What was the problem with amp?
Subsonic Filter. For some reason the 4Kw's don't want to work with the filter turned off. It seemed to work fine in testing when I turned it on.
New Subs:
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif G basket but not the G motor what did this get reconed to ? but everything else looks real nice
I did a bit more wiring today. I finished the "Big 3". I have to say, the alternator is a royal pain in the azz to get at! I had to remove the skid plate and do everything from underneath the truck. All wire is 2/0 awg.
Alternator positive to battery positive.
This is a view of the back of the alternator:
Side view of the alty (from underneath the truck):
Here is the chassis ground. I decided to go directly to the frame. The yellow 2/0 awg wire you see is from the engine block to the frame. The 2/0 awg blue wire is from the frame to the battery. Yes the blue wire connector has been taped up with black electical tape.
I also have a ground going from the battery to the chassis in the stock electrical ground location. There really is no need for this, but I did it anyways. You can never have enough ground!
valin
The King of the North
valin
Sudbury, Ontario
valin
ThxOne
    May 13, 2026
