Truth About Hifonics?
what were the specifics of this test? sounds a little low to me, seeing as the bx1500 loyd tested last year did much better.
I read the whole thread, 1605D, 870 watts at 1.1 ohm @ 11.5v... Hifonics amps power are rated at 14.4v, also it was in a vehicle with a low battery and a stock alternator.
gotta link?
i take it that the test was done in car on a burp. what were the voltage and current readings? was the 1.1ohm nominal or actual impedence?
There must be something wrong in that test
A bx-1600d can put out like 1200-1300rms @1ohm 12.5v
They are indeed overrated but not that much they have live 80% maybe a little less eficcient
Your bx-1000d will put out somenthing like 800rms@1ohm
The brutus amps may be overrated but they are great in the best in price/performance
and i have a friend runing a bx-1000d 0.5ohm daily with 4-8"dvc woofers
It gets pretty loud.
I talked my self out of the whole cheap power spend as little as possible... I am probably getting Phoenix Gold Xenon amps instead of HiFonics. I have always heard PG was good... They are still right?
Their new lines are not as good as the previuos ones you should consider kicker - mtx - orion instead of a xenon amp.
The xenon line is known for having lots of problems you should read about it in other forums.
Harrison486
Harrison486
New Jersey
Justintoxicated
michigan born
    May 14, 2026
michigan born
    May 14, 2026
