Trunk Boxes - Classic Car
  • 6
  • Participants list
mjasinsk
I have a numbers matching 1968 Convertible Camaro. I want to do as little modification as possible. It currently has just the factory 4 x 8 speaker in the front dash (lame) and an AM/FM converted head unit.
I am wondering if you can do 1 box in the trunk with the SUB, and the mids facing the back seat.
I have ordered re-popped kick panels that I don't have an issue modifying for front speakers.
I just wanted to modify as little as possible while adding some amazing sound.
Has anyone been successful with a box with a SUB on one side coupled with a box for Mids on the front side?
Something that looks like this... and please if this is a dumb idea feel free to tell me so.
25427
If you have some spare kickpanels that you can modify that would be infinitely superior to trying to run mids and highs in the rear. You should not need much by way of sub-stage to keep up in such a small car (assuming it isn't a convertible) so figure out precisely how much airspace/volume you wish to sacrifice for a sub, what diameter components you can get in the kicks, and how much power you'll have on tap and I'm sure you can get some good suggestions for something that'll work well for you there.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
646
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
873
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
mjasinsk
mjasinsk
Newark, Delaware
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
