Trojan issue...
JimJ
Tangled Up in Blue
No, not *that* kind of issue...
I picked up a trojan from somewhere, and it's been annoying to get rid of it. Doing a scan with AVG lists it as "Downloader Generic2.TGT" and there's a "d.exe" that's on my C: drive. Another program is in my temporary internet files. Deleting both these doesn't work, they just reappear on startup.
I can't do a system restore to an earlier point, because it apparently deleted my previous restore points.
Any other tips from people who have had this happen to them? Reformatting is an option, but I'm really not looking forward to doing that again...especially when I can still get into Windows.
1) reboot in safe mode with networking
2) Set view system files and folders and all hidden files and extensions
3) delete c:\temp (whole folder)
all files in the following folders:
c:\windows\prefetch
c:\windows\temp
c:\documents and settings\(all user accounts - go through them all)\local settings\temp
c:\documents and settings\(all user accounts - go through them all)\local settings\temporary internet files\content.ie5\ (all folders - delete them all)
c:\recycler
4) turn off system restore)
5) download, update, and run the programs:
ad-aware se
spybot search and destroy
ewido (http://www.ewido.com)
6) run this: http://www.trendmicro.com/spyware-scan/free_spyware_scan.asp
7) download run and save a log file with this program. Also post the log file here so I can review it:
http://download.hijackthis.eu/hijackthis_199.zip
8) once we go over the log file, head here: http://housecall65.trendmicro.com
tell it to use java and do a complete scan. when done, scroll to the bottom of the page and click "fix problems" or "remove" or whatever it says.
You should be right as rain, or close to it.
This is the "generic" process I follow at work when dealing with viruses. If this doesn't fix it, then I go in depth. Usually after this point, I can pinpoint the problem and just flat out target it.
For now until you find a permanent removal solution, you can mess the virus up by booting into safe mode, opening up that d.exe in any text editor, filling it with nonsense or "%@!# YOU!" and then setting it to read only so that the file is basically useless. You might get an error when your computer starts up, but the virus will basically be screwed. Its a great way of dealing with files that you can't delete.
i used to make an exe file with visual basic that all it did was open up, after 30 seconds it would close itself. i would rename the .exe file to whatever file i was having a problem with and replace it. that way the file still exists, but nothing happens. i did that on all the files there were causing the problem till i narrowed the problem
Tried doing what Hundreth said...couldn't open the file even in safe mode...and the problem got worse //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif Now I have a whole bunch of .exe's running around.
I'm running another scan...I have Avast already loaded, maybe it'll do something that AVG didn't so far...
Logfile of HijackThis v1.99.1
Scan saved at 11:23:30 PM, on 10/16/2006
Platform: Windows XP SP1 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\System32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\system32\rundll32.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\Explorer.EXE
C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe
C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe
C:\WINDOWS\System32\twinmpes.exe
c:\windows\system32\oldsregl.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
C:\WINDOWS\SmltIEppbmdvemlhbg\command.exe
C:\WINDOWS\system\dllhost.exe
C:\Program Files\Network Monitor\netmon.exe
C:\WINDOWS\System32\wltrysvc.exe
C:\WINDOWS\System32\bcmwltry.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\Program Files\Grisoft\AVG Free\avgwb.dat
C:\Program Files\Opera\Opera.exe
C:\Documents and Settings\Jim Jingozian\Desktop\hijackthis\HijackThis.exe
R3 - URLSearchHook: (no name) - {A8BD6820-6ED7-423E-9558-2D1486B0FEEA} - C:\Program Files\DeluxeCommunications\DxcBho.dll
F2 - REG:system.ini: Shell=Explorer.exe, C:\WINDOWS\System32\jfwid.exe
F2 - REG:system.ini: UserInit=C:\WINDOWS\System32\userinit.exe,C:\WINDOWS\NT\nrcs.exe,taemnbx.exe
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe /STARTUP
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKLM\..\Run: [!AVG Anti-Spyware] "C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe" /minimized
O4 - HKLM\..\Run: [ms032855790155] C:\WINDOWS\ms032855790155.exe
O4 - HKLM\..\Run: [ikte8f5f] RUNDLL32.EXE w00af0a8.dll,n 005e8f5a0000000300af0a8
O4 - HKLM\..\Run: [{EB-B2-2E-EE-ZN}] c:\windows\system32\oldsregl.exe GEN001
O4 - HKLM\..\Run: [ExploreUpdSched] C:\WINDOWS\System32\twinmpes.exe GEN001
O4 - HKLM\..\Run: [DeluxeCommunications] C:\Program Files\DeluxeCommunications\Dxc.exe
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [DeluxeCommunications] C:\Program Files\DeluxeCommunications\Dxc.exe
O4 - Startup: TA_Start.lnk = C:\WINDOWS\system32\dwdsregt.exe
O4 - Startup: Think-Adz.lnk = C:\WINDOWS\system32\twinmpes.exe
O4 - Global Startup: Adobe Gamma Loader.lnk = ?
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O4 - Global Startup: kdsfj.exe
O8 - Extra context menu item: &Yahoo! Search - file:///C:\Program Files\Yahoo!\Common/ycsrch.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O8 - Extra context menu item: Yahoo! &Dictionary - file:///C:\Program Files\Yahoo!\Common/ycdict.htm
O8 - Extra context menu item: Yahoo! &Maps - file:///C:\Program Files\Yahoo!\Common/ycmap.htm
O8 - Extra context menu item: Yahoo! &SMS - file:///C:\Program Files\Yahoo!\Common/ycsms.htm
O9 - Extra button: (no name) - {4ABF810A-F11D-4169-9D5F-7D274F2270A1} - C:\WINDOWS\System32\dmonwv.dll
O9 - Extra 'Tools' menuitem: Java - {4ABF810A-F11D-4169-9D5F-7D274F2270A1} - C:\WINDOWS\System32\dmonwv.dll
O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: AIM - {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - C:\Program Files\AIM\aim.exe
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (YInstStarter Class) - C:\Program Files\Yahoo!\Common\yinsthelper.dll
O20 - AppInit_DLLs: dxclib303562752.dll
O20 - Winlogon Notify: H323TSP - C:\WINDOWS\system32\shrio800.dll
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - Unknown owner - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: Ati HotKey Poller - Unknown owner - C:\WINDOWS\System32\Ati2evxx.exe
O23 - Service: avast! Antivirus - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: AVG Anti-Spyware Guard - Anti-Malware Development a.s. - C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
O23 - Service: Command Service (cmdService) - Unknown owner - C:\WINDOWS\SmltIEppbmdvemlhbg\command.exe
O23 - Service: COM+ System Service (DLLHOST) - Unknown owner - C:\WINDOWS\system\dllhost.exe
O23 - Service: Network Monitor - Unknown owner - C:\Program Files\Network Monitor\netmon.exe
O23 - Service: Windows Vista/NT Runtime Compatibility Service (ntrcs) - Unknown owner - C:\WINDOWS\NT\nrcs.exe (file missing)
O23 - Service: Windows Overlay Components - Unknown owner - C:\WINDOWS\dwmputz.exe
O23 - Service: WLTRYSVC - Unknown owner - C:\WINDOWS\System32\wltrysvc.exe
JimJ
Tangled Up in Blue
JimJ
Hillsborough, NC
pwnt by pat
Mike Mccabe
