Triangle Port
make a square then, or a rectangle.
i don't care what you dumbass have to say but if you take 2 equal triangles and put them together you'll either make a rectangle or a square end of that discussion. i just want to know about port length for a triangle shaped port. thanks for those that actually contributed something to this.
i bit pissy?
i was just stating the geometrical facts //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
and you are still wrong, btw
I saw someone with a triangle-shaped port at a USACI event last year and his mojo 15 put up some serious numbers in it. Almost 170db doing port wars, in the mid 140's in the kick.
Sounds like major turbelance/restriction to me which is good for port wars, but not so good for SPL or sounding good...
Assuming this is a daily box then I'd probably do a little more port area then normal just to be safe. Maybe 14^2 per cube if your sub normally requires 12^2 per cube.
Throw up some pics when it's done...
a square is 2 triangles no matter how it's done, no matter what kind of triangle b/c a square cut from one corner across to the next makes 2 triangles. so you can quit being a smart *** with your total of 20 post. maybe next time you can just save your sarcasm for someone else. I just want to know about calculating port length.
hey ******, since you think you know what the fawk ur squakin about, take your two equalateral triangles (which has 3-60degree angles in case you don't know)
and you tell me how in the fawk you make a square (which has 4-90 degree angles in case you didn't know that either)
go play in traffic somewhere azzwipe (on the freeway preferably)//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:
fasfocus00
doITdaWHITEwayORdoITtwice
fasfocus00
New Orleans, LA
RAM_Designs
