Triangle Port
fasfocus00
doITdaWHITEwayORdoITtwice
so, i'm deciding on a triangle shaped port for a box. i've always stuck to square/round/rectangle shaped ports. I had a thought for a design and was wondering does anyone have a way to calculate the port length. Or can I just calculate it the same as a square port since a square is pretty much just 2 triangles?
a square is NOT two triangles dude unless both were right triangles and then your port would look wierd. use an equalateral triangle port that would look original and sweet especially with beveled edges. look up triangle volumes on google for area
a square is 2 triangles no matter how it's done, no matter what kind of triangle b/c a square cut from one corner across to the next makes 2 triangles. so you can quit being a smart *** with your total of 20 post. maybe next time you can just save your sarcasm for someone else. I just want to know about calculating port length.
which would be 2 right triangles, as a square has 4 right angle corners.
a rhombus is not a sqaure, although it has 4 equal sides. and two of the same tiangle will not always make a square //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
smartass
smartass
i don't care what you dumbass have to say but if you take 2 equal triangles and put them together you'll either make a rectangle or a square end of that discussion. i just want to know about port length for a triangle shaped port. thanks for those that actually contributed something to this.
the word you're looking for is quadrilateral //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
fasfocus00
fasfocus00
New Orleans, LA
RAM_Designs
michigan born
    May 14, 2026
michigan born
    May 14, 2026
