Tri-Sub Box Design
  • 6
Reddish Neck
TD's & Beer
I'm working on a new box design for 2x10" subs and 1x12" sub. This is just a mock-up of what it will look like so far. The black shapes are vents. Let me know what you think.
i'd be real carful doing a design like this. make sure the box is built properly. this includes sealing off each woofer into their own chamber, running seperate amp for each woofer (at least the two tens from the one twelve), and make sure the port is designed correctly.
---------- Post added at 02:23 PM ---------- Previous post was at 02:22 PM ----------
atleast his name matches is condition.....
dont mix and match subs period....wether ur just trolling....or being serious
Wow, for one I'm not the one trolling. And I'm fairly new to car audio but I want to come up with something different. The whole reason I posted it was to get peoples opinion on whether it's a good idea. Obviously it's not the best idea so calm down.
69
Sensitivity is usually measured 1watt 1 meter. I'd go by that. Higher the better on subs too. Less power to get louder. Every 3 DB gain is like...
149
I've been a fan of the JL shallow mounts, and have actually heard a decent box with some Pioneers but the Focal are pretty darn good. The JL TW's...
259
280
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
282
Reddish Neck
TD's & Beer
Reddish Neck
Racine, WI
Falcons
SlugButter
    May 4, 2024
slater
    May 2, 2024
