tri-mode
The amp should be able to play the left and right
stereo channels while playing a third (bridged)
mono channel.
I've heard it called Tri-Mode and Mixed Mono
i would have said that one lets say 200rms @ 4 ohm signal going to any given set of speakers could be intercepted by a trimode filter making it send a high @ 200wrms, a mid @ 200wrms and low @ 200wrms (signal separation)
It's one of those BS features a lot of cheap amps will mention when they don't have anything else worth talking about. Any bridgable amp can do it.
It's usually associated with a 2 channel amp. All it means is hooking up a pair of speakers like normal, and then using an 8 ohm (4 will cause a major strain on the amp) speaker and wiring it to the terminals you would normally use for bridged mode. Effectively it drops the amp to 2 ohms stereo, but the 3rd speaker would be running in full range - you would have to have an in-line low pass crossover if you wanted to run a sub using "tri-mode".
Originally posted by n2audio It's one of those BS features a lot of cheap amps will mention when they don't have anything else worth talking about. Any bridgable amp can do it.
my Zapco amp is stated as Tri-mode capable.. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
well, it can actually be quite useful in lower power applications...
you can run 2 speakers and a sub off one 2 channel amp... if you ont have the flow fora second, or just need a little bump for an 8" driver under the dash, it can be quite useful... just remember, just because it isnt common, doesnt mean it can't be useful
i3abyjay25
Get F'n Loud
i3abyjay25
Dallas, Georgia
Wonderbread
