Treo TE subwoofers, any info on this new line?
Precision CNC-machined low-carbon steel 220 oz. motor structure
Large diameter pole vent
High-excursion motor structure and suspension design
Tall extended displacement composite foam surround
Resin impregnated poly-cotton damper for superior cone control
Mica-impregnated polypropylene hybrid cone
Integrated tinsel leads for increased reliability and sound quality at high excursion
2.5" high-temp aluminum voice coils
500 watts RMS power handling
Dual 2 ohm voice coils for unlimited installation flexibility
Optimized for small sealed, vented and bandpass enclosures
Woofer Size: 12"
Nominal Impedance: Dual 2 Ohms
Cutout Size: 11"
Mounting Depth: 6-3/4"
Voice Coil Diameter: 2.5"
Driver Displacement: 0.08 cu. ft.
Power Handling: 500W RMS
SPLo: 84.77dB
No: 0.19%
Sd: 78.5 sq. in.
Fs: 24.241Hz
Vas: 2.532 cu. ft.
Qms: 3.828
Qes: 0.524
Qts: 0.461
Cms: 196.680 uM/N
Mmd: 212.607g
Mms: 219.165g
BL: 16.928 T-M
Levc: 2.285mH
X-Max: 1.1"
Recommended Sealed Enclosure (net): 1.1 cu. ft.
Recommended Ported Enclosure (net): 1.6 cu. ft. @ 31Hz
i had a single SSi 10 ported off 800w and it was very loud but didn't have much output above 55-60hz. i need to decide whether to go with dual 4(695w) or dual 2(939w) on a single 12.
i also have a ten inch ssi on 750 watts ported at 35hz and it does fall off up top. i set my crossover at 63hz instead of 80hz for that reason. it does get really loud on the low notes though, but i'm craving more power. i know it can take more.
but like everyone else is saying you cant go wrong with treo.
Any truth to the above statement comparing it to the idmax?
I dont think enough people have heard the new models to make that comparison yet. Your best bet is just calling Treo and asking them. treo subs can handle a lot more power than they are rated for and get very loud.
i talked to a guy @ treo yesterday, he said it fits between the tsx and ssi lines so it should still get loud(they both do). i also asked him about the power rating and he said their rating should keep the sub happy during its 3 year warranty, any more power might shorten the life. the single 12 idmax i used to have was plenty loud, looking for something comparable that i can bang on without worrying about issues.
does anyone know where I can find ther new line of subs??? I cheacked there site but it looks like everything is from 2004, thank you
yea they need to update their site very badly.
everybody says that the treo's can take way more power than rated at. does anyone know how much the 10 inch SSi should take daily? i have it on 750 right now which is what they recommend but i know it can take more but i don't wanna kill it. i want to get a bigger amp but just don't know how much i should give it.
JoeHemi57
JoeHemi57
Little Rock, Arkansas
Flipx99
