Torres Vs Re Calc...Port Length Confusion?!?
  • 4
DJSlowfets
CA
Im about to start throwing shi* at this point...basically Im trying to make a box for my American Bass XR-15
I want 4.2 cubes +/-
30-32 hz
Torres and Re are both giving back contradicting answers.. my two questions are as follows,
Re Box is somehow arriving at the answer that a SQUARE L Port with the exact length of sides of 16 inches which I would think would make 32 inches of total port...16x2=32 pretty simple math right? but RE is saying that with both port walls of 16x16 somehow equals 38.37 ? How do they get that from two 16 inch pieces?
Which then follows up to my second question Torres asks for port length do I give them my answer of 32 like in the picture linked below or do I input RE's calculated port length ? Because if I do one or other it changes net space and tuning dramatically...
TL;DR Im linking a screen cap of the same measurements of a box I made up on two different box calculators and im getting different results? Also Do I use 32in as total port length to input in torres Calc or Re's Calc math of 38 inches for total port length
SCREENCAP LINK http://imgur.com/a/5YmyJ
Any advice appreciated!
Lots of people have said the RE calculator is bogus.
It's free, easy to use, and looks nice, but it is not acoustically accurate.
Torres is the more reliable tool.
Ok So Should I use 32 or 38 for "total port length in Torres if my L port will be 16x16?
Iirc RE tunes the box higher than it says. Like if it says 35, it is actually like 37 or 38.
Still, its a good tool to visualize the box, but more reliable equations should be used
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
996
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
694
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
867
837
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
DJSlowfets
DJSlowfets
CA
Papermaker85
    May 16, 2024
    May 16, 2024
