djdownfawl
I am powering a set of CDT es62i GOLD components with an ARC 300.4 amp and i can't turn up the volume more than 12-14, the speakers crackle, and it sounds really bad.
They are currently hooked up bridged.
Bass boost on the amp is turned up 1/8th
Gain is turned up 1/8th
All lower frequencies on the H701 are on zero
Turning down the gain and bass boost might help, but what i am asking is can i use this amp for the rears too instead of just using it for the front.
So if i use it for the rears too its going to run as a 4 channel amp and i won't be sending too much power to the cdts...
CDT Specs
http://www.cdtgold.com/es62i_2.htm
ARC 300.4 Specs
http://www.arcaudio.com/productdescription_pages/amplifiers/ks-series/ks3004.asp
CDT Specs
ARC 300.4 Specs
