Too much power for LOC?
LM950
when I turn the volume on my deck around halfway the bass plays fine for a while, then the volume will drop and come back and drop again. When I turn the volume back down everything is good again. I've checked connection's, swapped RCA's, swapped amps, swapped stock headunit ipod adapters, and the problem still persists. My LOC I'm pretty sure I got from autozone a while back. Has anyone else had this problem?
I ran a loc for almost two years and blasted the sh*t outta it never had any issues. It is the cheapest option to try though so might as well start there. Still sounds like thermal shutdown to me also though.
Failing amp or failing LOC.
Dumb question, but does your amp have speaker level inputs that you could try out direct from headunit and bypass LOC altogether? I sure don't see many amps nowadays without high level inputs.
LM950
LM950
Louisville, KY
negolien
