Too good to be true?
TonWardHD
CarAudio.com Recruit
33
I’m in the process of receiving 4 3600 rms amps directly from a company in South Korea. This is the same company currently sending shipments to PSI, DS18, and wolfram.
im getting each amp at $300 each including shipping. A total of $1200 for 14k rms??
havent paid yet but at the point to where I can. I must be missing something right?
Yeah but Korean amps seem to be the most reliable. Should the taramps be rated at 370 amperage musical consumption when it’s also listed at 8000 watt rms?
impedance rise plus music not being a 0 db test tone makes it so you never draw 800 amps.  Same goes for korean amps unless you wire them to the dirt.  Most music is -5 db or under with pauses between music so you'll never be getting the power you think you are getting being wired to just 1 ohm, you'll need to look at 2-4 ohm numbers and thats where you will actually clamp clean.  Only advantage korean had was being able to wire to the dirt but now taramps has the bass series which can be wired to the dirt as well, reliability is just as consistent as koreans, i've seen equal amounts of blown amps from both camps, except taramps has actual warranties while koreans leave you shit out of luck.
TonWardHD
TonWardHD
Jeffdachef
