To the people whove dealt with 18's. Need input
Millertime1028
I need some help/advice ... Allright , so this is where im at . I currently have (2) AQ 15 inch sd2.5c's ran off an AQ2200d in my Jeep Cherokee. Im looking to upgrade a bit more but while still having the option of using my AQ2200 in the next setup . My current setup did a 156.1 at the kick on a AC mic so im looking into possibly 18's for the next setup . I have 10.5 cu/ft to work with if I use precision ports . I was looking into the MJ-18m's but was not to familuar on their output . They are efficient as all hell but I know they were not built with the intent of spl#'s . If someone can suggest different subs or just state their opinions any help would really make my decision alot easier . I appreciate any input . Thanks
well there are the obvious choices..BTL, HDC3 18", Treo, DD..
whats your budget and whats your power? I love the MJ-18"s, but they wouldn't be my first choice if I wanted a crazy loud car.
10 cubes is enough for a 21in Death Penalty
2 18"s have moar cone area //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
And he can get away with 2 18"s in 10.5 cubes using aero's, it'll be tight but it can be done.
If you want to keep the 2200D and not upgrade or strap them, you can go with 2 18" Q's or BL's, or some 18 proto's, you have tons of options depending on budget.
well there are the obvious choices..BTL, HDC3 18", Treo, DD..whats your budget and whats your power? I love the MJ-18"s, but they wouldn't be my first choice if I wanted a crazy loud car.
Trying to stay around $500 for the subs . This is my daily driver so yea , I have the AQ2200 installed and will most definitly stay with it .
Ok..well maybe look for 2 used hdc3 18"s? I think they would be in that range. Not too familiar with the Fi pricing so maybe look at the BL or Q's? A lot of companies around make great equipment so just go search around.
actually id recommend going with 15"s because in a box that size they would be more efficient with that power than getting 2 18"s in there.
39hz .. with 850 to each sub .. Used a 48hz sine sweep .
I almost find that hard to believe. A lot of people running HDC3's tuned higher than that with more power are just breaking 150's.
But hey, if its the truth, that's a sick nasty score! Pics of your setup?
we tested 2 15" DD99Zs and got .3 dB louder than the 2 18" DD99Zs. The air volume just worked beter for the 15s.
So be sure that your box volume will work and dont be surprised if your SPL goes down.
Millertime1028
Millertime1028
Long Island, New York
Millertime1028
