to: the people who do walls and door panels...
Tek18
5
KY
Im curious, i would love to re-do my door panel with 2 midbass and 2 tweets that are bigger, but, what do you do when you re-sell the car or something comes up where you have too? having a door with holes in it is not going to be good to re-sell...
or when you all make huge holes in the bottom of the car so you can wire through, make boxes, destroy the trunk to put the stuff in.
im just curious
If you are cutting metal in the car you have no plans on resale in most cases. However, do make custom panels and such there is not a need to cut anything in most cases.
I have 5 sets of components in my doors(4 door truck) and a wall with 4 15s and I have cut no metal anywhere.
door panels if done correctly can still look stock until you look behind them.. holes in the floor are covered by carpet.. walls can be installed and removed without anyone knowing different minus damage caused by the bass.. LARGE amounts of painters tape is your friend it keeps expanding foam off of the headliner and other areas..
Tek18
Tek18
KY
KyleBechtold
