To high of an RMS rating?
well First off is it 250w rms or 250 w max Ive never seen a Max RMS rating its usually 2 different ratings. If its 250 RMS I would say you should be ok but only if everything is set up and tuned properly.
depends what the sub is, what is it?
Sub: Kenwood KFC-W12PS Performance Series 12" 4-ohm component sub at Crutchfield.com
Amp: Kicker 11DX250.1 Mono subwoofer amplifier — 250 watts RMS x 1 at 2 ohms at Crutchfield.com
---------- Post added at 04:03 PM ---------- Previous post was at 04:02 PM ----------
What sub is it? Jl is the only company that I know does that but they give a range like 60-250wrms were 250 is ther max rms but in real terms its just regular rms
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
300
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
904
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
759
Trevaughn
Trevaughn
Big Rapids, MI
RSDXzec
