to bypass a factory amp or take it out
ekah
hawaii
my mazda 6 2006 s grand sport comes with a stock bose system that i had a car stereo bypass because at the time i didnt wanna get into bypassing it but i was wondering if i can throw out the amp instead of just bypassing it? they told me i needed to bypass and thats the only way to have a new amp installed. i thought why cant i just throw out this bose amp? is it because the stock harness goes to the factory bose amp and then to my speakers? if so can i just run all new wires to each speaker? since im trying to go active anyways/
any thought?
My Tahoe has a factory amp as well. So here's what I did: just unplug the harnness and used a few wires from it that were powering my rear door speakers. Just left the amp in it's place, which is up under the dash.
Depending upon where that Bose amp is located, find out what speakers are being powered from it and just unplug the harnness and bolts/screws it has secured to it. Write down on a piece of paper what color wires are powering which speakers. Make sure you don't have more than one amp too.
Rip all that Junk out and put a real stereo system in..saves time and hassle..along with issues
so wire speakers straight back to 4 channel amp ppi900.4 instead of wiring to radio or stock amp etc?
Yes..bypass existing amp, or you will have conflicting issues..If the Head unit has a built in amplifier, it would be best to replace for external amplifiers and less hassell/incurring conflicts/issues/headaches and time saving and and less $ pit issues.It saves time and you will retrieve better results.You will know exactly where every wire goes to as speakers and source and be able to make any additions easily within the future without any headaches/conflicting issues.Thats my recommendation
so when you say bypass can i just yank out the existing amp out of the car and run a pair of speaker wire going from the tweeter and mid woofer on left door and run it straight back to 4 channel amp and run right door speakers straight back to amp? the rca is the signal and the speaker wire is the power and ground pretty much right?
a shop has a 9 wire going to my ppi900 from the stock amp is all its doing is stealing power and ground for each speaker wire? im not sure of the real basics of whats going on lol why i have to bypass and why not i can just unconnect and throw the amp out compares to them using this 9 wire speed wire. sorry if this sounds confusing
Thanks for all suggestions and all is installed and working great.
13
873
How exactly would I do this for after market amp and since factory is 14 channels how would I get close to the factory amp? I hit a curb on...
Please excuse this extra question .. Is there a specified patch lead or compatible bypass harness for the factory amp or would I have to create it...
863
Your crossover slopes will be steeper ..so sharper cutoff points ..say deck is 24db and amp is 24db youll have a 48db slope the subs will still...
That doesn't make any sense. The directions say to hook it up to the parking brake. The parking brake is engaged when the car is off. You...
17
6K
ekah
ekah
hawaii
ekah
audiobaun
    May 19, 2024
    May 19, 2024
