maltaudio 10+ year member
Hi Guys
Car audio newbie here.
I have a Focal Solid 4 Amp and a Focal 165 VRS component speaker set.
I would like to know whether you would recommend bridging the speakers? I have no rear speakers, except a sub, which has its own dedicated monoblock amp
Here is some info on what I have
Amp info:
Frequency response 10Hz - 60kHz
Input sensitivity 0.2 - 5V
Maximum cross section of power cables 35mm2 - 2 AWG
Dimensions (HxWxD) 13/4 x 1113/16 x 77/8" (45x300x200 mm)
Signal/Noise ratio (1 Watt output) >80dB (A)
Nominal power measured at 14.4V continuously into 2 Ohms THD + N
THD + N @ 4Ohms 0.02% @ 1kHz
Signal/Noise ratio (RMS) > 100dB (A)
Damping factor @ 4 Ohms 50 to 1kHz
Input impedance 20 kOhms
High-pass filter 50 - 150Hz (12dB/oct.)
Low-pass filter 50 - 150Hz (12dB/oct.)
Remote control YES
Maximum cross section of speaker wires 10mm2 7 AWG
Fuse(s) 2 x 25A
Nominal power measured at 14.4V continuously into 4 Ohms THD + N
Power in bridged mode measured at 14.4V continuously into 4 Ohms THD + N
Component set info:
Nominal impedance 4 Ohms
Depth from wall shallow mounting: 56mm (2-3/16")
Max. power 120W
Nom. power 60W
Sensitivity (2.83V/1m) 93dB
Frequency response (+/-3dB) 70Hz - 28kHz
Magnet Neodymium
Voice coil 32mm (1.25")
Tweeter TNB tweeter, aluminum/magnesium inverted dome
Woofer 165mm (6.5")
Cut-out diameter 141mm (5.5")
Controls Tweeter level: 0, -3, -6dB
Product type 2 way kit
Type 2 way kits
Diameter 6'' 1/2
Amp info:
Remote control YES
Fuse(s) 2 x 25A
Component set info:
Max. power 120W
Nom. power 60W
Magnet Neodymium
Woofer 165mm (6.5")
Type 2 way kits
Diameter 6'' 1/2
