tline enclosure for 6.5's (exodus anarchy)!!!!!
  • 6
CerwinVega_Fan
Coolest Member
4,474
Dallas,TX
I literally just got a pair of 6.5 Exodus Anarchy Mids. I highly doubt they will fit in my doors and I'm satisfied with my daytons I have in my doors.
I want to try my new exodus mids in a tline box and see how well they do as a sub stage.
Any ideas?
Any ideas?
What are the Fs and Sd of the drivers?
SPECIFICATIONS
Fs = 45.8HZ
Qes = 0.48
Qms = 6.37
Qts = 0.44
Vas = 9.61L
Sd = 131cm^2
Xmax = 12.5 mm one-way
Re = 6.4 Ohms
Le = 0.84 mH
BL = 10.79 N/A
Power: 125W Approx: No IEC testing conducted
Spl = 84.7 dB/1W/1M
I wanna see it happen!
Oh it's gonna happen! If they don't do well in my car I will use the in some sort of home audio setup.
Those will do well in a line. You can make it 6.16' long to tune it to the drivers' Fs or, you could tune it a bit lower since you're planning to put them into sub stage use. Seven feet long would tune them to ~40, which would probably be really nice plus, they should still have some impact all the way down into the 20s, although frequency response is probably gonna hurt that.
Build it for me //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
I'd love to. I have a line for a custom built old school Earthquake Magma I built going to Orlando next week so why not build two? Or three? I've also got a couple of AB 6.5" subs I'd like to build one for so maybe I can design yours and mine at the same time... I think the ABs have a similar or slightly lower Fs and the Sd is probably real close.
You should make that horn. There's a lot of work went into that and it seems really solid.
I really want to. But I don't want to pay a fortune to have it built. I would try my luck and build it myself but I don't have the time, tools, or space to build it.
Let's make it happen!
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
637
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
CerwinVega_Fan
Coolest Member
CerwinVega_Fan
Dallas,TX
CerwinVega_Fan
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
