time to upgrade couple ???'s
bigandy
i drive an 04 trailblazer with a 140 ampalt with a 34 series YT
i was running 900 watts rms with slight dimming while stopped
i am already upgrading my wiring to 0 gauge plus i am going to do the big 3
do you guys think i can get away with 2000 rms or should i play it safe with 1500-1600
i dont want to have to change out my alternator
and ill be running 2 15's in a ported box if that helps any
i also have access to deka batteries right up the street to if that will be a huge upgrade over the YT
thanks in advance
i think doing the big 3 in 0 or bigger and adding the biggest deka up front should help if theres still a problem its not hard to add another run to the back and throw another g31 deka in the back and that should be fine
all a battery is is a voltage stabalizer while your car is on all the power is coming from the alt unless voltage drops to 12.6 or below adding more batterys to a system with the alt isnt keeping up is going to add more stress to ur alt because it will have to charge the batterys more and longer
bigandy
bigandy
ontario, CA
DammitJames
