woofercooker 10+ year member
A Gentleman and a Scholar
Sundown Audio e8s will fit the bill... Available for 60+shipping each through me. These are b-stock subs that I am refurbishing with all brand new parts.
amen!he asks for tight punchy bass, and people start recommending brands and sizes of subs.//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif the box is going to dictate the sound far more than the actual sub. a smaller box will be punchier, and probably won't perform as well on lower notes. some sub manufacturers will actually give you box sizes that specify this. focal is an example. smaller box = tight punchy bass. bigger box = deep articulate bass.
lol:laugh:You have to get little subs. The smaller the subs the tighter/punchy the bass. I'd look for some 1'' subs. /sarcasm
i think he should go with this one. far more cone area than a small 1 inch sub.You have to get little subs. The smaller the subs the tighter/punchy the bass. I'd look for some 1'' subs. /sarcasm
BINGO!!! My 2 12" Polk SR124-DVCs hit extremely tight and punchy in my box. Its a sealed, chambered box with 1.16cft per sub before displacement, and each driver then displaces 0.14cft. I really like it, but have thought about going to a slightly bigger box to the Polk recommended 1.20cft after displacement to see how it sounds. Of course my SRs are also very SQ oriented. But definitely go small sealed if you want tight, accurate, punchy bass.he asks for tight punchy bass, and people start recommending brands and sizes of subs.//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif the box is going to dictate the sound far more than the actual sub. a smaller box will be punchier, and probably won't perform as well on lower notes. some sub manufacturers will actually give you box sizes that specify this. focal is an example. smaller box = tight punchy bass. bigger box = deep articulate bass.
i wish i could do ib, but i have an extended cab truck. heard a couple of focal subs done infinite baffle and it sounded really good. not overly loud, but it rattled the rear view sufficiently enough for most people's daily vehicle.an IB set up with a good woofer ment to do so sounds better in almost every way than a boxed up sealed woofer or ported box. It is tighter and sounds more "real" and can get low and still have a smooth roll off at the higher frequancies.
There's plenty of rap that has tight punchy bass.Since when does rap have tight/punchy bass //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Actually you can..just have to do a build to box to the back end of the cab and cut some holes in the back of the cab. make an awning type frame with a couple layers of gortex in side of it to keep the water out and bolr/seal it into placei wish i could do ib, but i have an extended cab truck. heard a couple of focal subs done infinite baffle and it sounded really good. not overly loud, but it rattled the rear view sufficiently enough for most people's daily vehicle.
