Thoughts on running 4 sundown SD-2 10's
tommydh
So I currently am running 2 D4 10 sd-2's on a BRZ 1700.1. My thoughts are either go up to SA-10's or comparable or add 2 more sd-2's. Please try and keep in th eprice range of these and keep iin mind that outside of a Big 3 upgrade I'm stock power. All my wiring is 1/0 OFC all input is welcome.
i may not be thinking clearly, but having 4- D4ohms, you cant run 1ohm nominal?
I could run it at 2 ohms on one amp I was kinda leaning towards second amp as well. I think 2 ohms would be ok the amp rates at 1200@2ohms
tommydh
tommydh
Baltimore, MD
RicksI30
