Thoughts about C2 audio recon amps?
I haven't seen that debate. Is maxxsonics building amps for AQ (DD) now?
The BRZ2400 and AQ2200 use the same board and have comparable parts and performance, yet I still see people saying "stay away from Hifonics it's junk" while at the same time saying "the AQ is a solid amp"
A lot of recommendations come from hype and not actual knowledge of the products.
thanks man I've already gotten a DC audio 3.5k since then and couldn't be happier. I figured I'd stick with something that has good resale value on the forums.
Korean board efficiency and design is awesome, noticeably louder, sounds better and volts drop even less than two hifonics brx 2400.1s.
Oops, DC was the other "cookie cutter" I forgot to put on that list. Lol. I had a DC 2.0k which uses the same board as a bunch of other companies amps. That amp pounded with authority but some guy wanted to pay me more than it was worth so I let it go and got this Korean built powerhouse for a steal. Although I do miss my wonderful Chinese built CT 1400's. I'm glad it worked out for you Jeff.
DD or sundown is not cookie cutter. Find another amp that matches footprint and power.
Just throwing that out there
What does this have to do with the question asked that started this thread?
The topic you are bringing up has been discussed at length in other threads.
If you have first hand experience with C2 Audio Recon or one of the mirror products your post will be appreciated.
Don't get mad because you BS was corrected.
Because most of the time bull **** gets said.
No one said a negative thing about your precious DD, we respect them just the same as the other companies who use the same board. But thanks for polluting another thread with your useless defensiveness. If DD is the God of car audio as you try to force everyone else to believe then start a thread about their products. This thread is about C2 Audio Recon amps as the title says.
Who else uses the same board? Find one..
You talk crap now back it up
It's right here in the same thread where you looked like the same butt hurt fan boy you do now.http://www.caraudio.com/forums/amplifiers/608806-dc-audio-2-0k-clean-power-2.html
All further comments by you on this thread will be ignored by me as you clearly have absolutely no useful or cunstructive information on this topic.
How about this for useful. They are not even the same size. I know you learnt your numbers in school. Keep repeating BS.
If I was stupid I would ignore me also.
Jeffdachef
Gunz That Turn on Nunz
Jeffdachef
South Coast Metro, CA
MrFoca
