amp not getting loud anymore?
jstone2020
18
pa
i have a kicker ix1000 its only a month old, anyways i got in my car today turned my headunit up and the subs were barely doing anything at all the only way they get louder is if i turn the sub all the way up on my headunit and then go on the amp and turn bass boost and gain all the way up and its still not sounding anything like it has been.. is this amp fried??
the subs were perfectly fine last night when i got home, its just this morning its like theres no power going to them. the power light is on with no protection light on, ill just try to hook it to different subs and see what happens
Check the ohm reading of the subs.
Sent from my Z970 using Tapatalk
i just checked the ohms and im getting exactly 2, i got this amp off hifisoundconnections it has a warranty so i can just send it right back
This may just be bad wiring or ground.
If it plays low, but after a few minutes does not play anymore then your ground is bad due to wire sizing or burned wires.
Just got new amp today and still not working. So i put back in my stock headunit with pac adapter and it works. I must've blown the preouts on my jvc headunit. Thank god for warranties
jstone2020
jstone2020
pa
Jeffdachef
