Thors 09 Build Log
you could always assemble the sub with a piece of wood already mounted to the backside of the sub and that way you screw the backplate to the box instead of the sub. as for it disassembled. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I know this I was joking about the mounting thing //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I will be keeping the HD3 motors but may entertain the idea of selling the HDC's.
If they hold up over the weekend...I think I'm entered in a Death Match:crazy:
heard bout them but never seen..
so its full tilt whoever's system burns up first loses?
Well do to some mechanical failure....Air Struts went flat.....I didn't make the show on Sun. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Woke up with my butt on the ground and wouldnt hold air....cracked t valve again...ordered a metal replacement and put another temp. plastic one in place.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
On the Good Side I'm told my new toys are coming along just fine.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
I know your not going to show them off till you show, but take some pics since we won't get to see them once they're mounted. I want to see how crazy these things are.
Also check if the glue is purple on the motor.
Will do Dave! I'll post lots of pics!
My first set of tests will be done inverted showing them 3.2 cu. 2nd round of testing will have them mounted traditionally which will show the subs 2.4 cu. or so after displacement of subs.
These things are friggin HUGE!!!!!
Took out 2nd Kinetik so that I'm legal for St. C and for WC1.
I plan on doing a batt bank on the passenger floor in the back seat that can be removable to be able to play in different classes and for Bassrace!
Will have copper buss bars next week. Started sealing it up permanently. Hoping to beat a 150.2 which is the best I've seen with 1 amp.
thorshammer1
thorshammer1
Auburn, NY
uGotF-ckedUp
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
