This sub fit the bill?
Alter Ego Trip
Witty Statement Here
243
MT
I'm currently installing a system in my 05 ext cab. I'm trying to keep everything looking as factory as possible (3 ways mounted behind factory bose grills, sub box built under back seat). I have an MTX TE1004 for powering my 3 way's and an MTX TE1501D amp for the sub. I'm all about SQ (with a little bit of SPL thrown in), hence running the 1501 and back peddling it quite a bit. I am currently running a single Boston G2 10" but am looking at replacing it with FiQ 10" or 12" sub in a 1.0cf sealed box. I'm not sure whether to get the Dual 1 or 2 ohm version. I'm leaning towards 2 so I can run a 4 ohm load which would produce the cleanest signal. It's only 500 watt's, but like I said I'm more of an SQ guy.
2nd option is to slap another 10" G2 in there running a 4 ohm load, at least I'd have a ton of headroom lol.
3rd option is a single IDQ v3.
All suggestions are appreciated on the above mentioned sub's or any other one's. I need to stay with a sub with a mounting depth of less than 7".
Raise that rear bench seat up 2". It'll still look stock and give you plenty more room to fit things back there then you had before. Check the link in my signature to see how I did it. My truck is the one titled "No Limits".
Alter Ego Trip
Alter Ego Trip
MT
smgreen20
vegang
vegang
