darkhunter139
K am I not touching any of the crappy brands.If it requires a heat gun to make it stick, 1) its most likely asphalt based, uhm ewwww, and 2) it is most likely breaking down the material as you heat it, rendering it less effective than if it hadn't needed the additional heat to set it in place.
The good shit, the real butyl based stuff with proper adhesive, requires NO heat to make it stick, and it actually increases its bonding strength the longer its attached.
Ill just do as much as I can with my roll of rammat that I have now then buy another one when I can afford it
