This is a Zv4, right?
Thank guys. I looked up the x2 and it looks like a match. He's saying "the exact model" is Z-15 V.4 D1 REV.2
Any ID marks I can have him check? I don't wanna insult the dude if he is wrong.
naw, ive seen some ****** drivers though. the holee s is freaking huge. no thanks. then and only then Id use a neo motor. things well over 100 pounds. sicks *** driver noone gives credit to.
Zv4 is nasty
Most def the x series version 2 You can check the website and do a comparison to match what's posted in the above links.
As you can see, the zv4 has a bumpbackplate whereas the x does not. Also....the x has a yellow spider. The zv4 has a black one.
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
980
Hello, I already posted in general but wanted to also post in here. I recently installed a set of used JL audio shallow depth 12W 1v3-4 inside an...
Makes sense. You may be right on the gain; 2 subs on 300 watts seems anemic.
46
4K
BanginBishi
BanginBishi
TN
Boomin_tahoe
audiobaun
    May 19, 2024
    May 19, 2024
