Josh_Dude83
Hello. This is my first post so go easy on me. So i was finally hooking up my amp/cap/sub setup. Everything was going good after setup, but the sub wasn't hitting as hard as i thought it should. I was tinkering with the gain and nothing. Let me state now the amp is a 2 channel RF punch 300s, should be 150x2. So after not getting much of a response I went to my head unit to tinker with settings. My head unit is a sony cdx-gt09. After fiddling with the settings I realized this head unit doesn't have a designated sub output and only by turning up the sub on the speakers does it also adjusts the sub. I turned sub to max on radio and then I got a little more hit out of the sub and decided to go back and turn up the gain on the amp. I started with channel 1 and slipped on the gain knob and cranked it. The sub hit really hard for about 4 sec then went dead.
So the dilemma here is where to begin testing to see what went dead sub/amp/fuse etc. The radio seems to be working fine. The amp is wired to the box with terminal 1 and 2 + combined to + on box, and terminal 1 and 2 - combined to - on box. I wanted to see if the amp was still outputing to the sub so i checked voltage at the sub box and was reading a constant 20-23V. The amp was still warm to the touch as well. I haven't found any fuses on the amp so idk what to do with that. Thought they usually had a fuse.
Even though the radio was still going I know there is a fuse on the back of radio and made me want to make sure there was still a signal from the radio to the amp but wasn't able to get a read on the input cables to the amp...any suggestions. I put voltmeter on the the male part of cables and then to outer ring and couldn't get any voltage reading. Yes the cap still has a solid voltage reading so I know I at least have power to there and to the amp. The amp LED is still on as well.
Next I took out the sub to find that it was a dual coil 2ohm 400W RF sub. The sub is wired: box + to terminal1 +, terminal1 - to terminal2 +, terminal2 - to box -. Where do I need to put the voltmeter to check the ohms and what reading should I expect?
I guess that is the most information I can give. Thanks in advance for any and all help in resolving this issue.
