this amp with this sub? problems?
If i were to wire this sub: http://www.ikesound.com/product-product_id/3158in parallel (to go from 2 ohms to 0.5 i think? ), would it work with this amp?
http://www.ikesound.com/product-product_id/1506
or would it cause problems since the sub is down to 0.5 ohms and the amp goes to 1 ohm (sorry i am just trying to learn all of this electrical stuff) any help is appreciated, thanks.
*shakes head @ Flakko's failure to read //content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif *
For starters - a Dual 2 Ohm sub with the coils wired in parallel will yield a 1 Ohm nominal load. That amp is rated for 1kW @ 1 Ohm. I have no personal experience with HiFonics' gear but I see it frequently posted that they are somewhat overrated - cannot say for certain if this is true as it is simply something I frequently see rather than something I know to be fact.
Be conservative with the gains (set them according to the method outlined in the Gain Setting Tutorial) and you should be okay.
I dont know much about Hifonics either, so could you suggest some alternative amps that can get the job done for around the same price? thanks
swiftone
swiftone
toronto, canada
swiftone
Mike Mccabe
