I Like Waffle
Banned
CS 144 Alternator, 180a i believe. 2 brand new Everstart maxx batts under hood
CCA: 875 amps
CA : 1090 amps
Reserve capacity: 165 mins
C&D 134ah batt in the trunk. Big "8" in 2/0 wire. 2/0 wire to rear batt, rear batt grounded straight to frame with 2 runs of 2/0, about 3ft each.
Not sure on the specs, but i got it load tested for 1597 CA @ 40 degrees after sitting in storage all winter. //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
1 run of 2/0 from each side of frame to alt bracket
1 run of 2/0 from frame to each underhood batt
1 run of 2/0 hot wire from alternator to each batt
1 run of 2/0 from each batt to the chassis
Wanting to run an AP3000 on four AP TXX 15s in 16 cubes in my car. Also about a 400w 4 channel, so ill be pulling about 350a at full tilt i suppose.
I have room for 2 more C&Ds in the trunk right now between the 2 8 cube boxes. But im gonna have to lift it in the back or lower it in the front, lol. //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
CCA: 875 amps
CA : 1090 amps
