Probably, but you may have to solder.O i have already got that plkanned but the wire that come out of the tweeter...Can you change that?
Those comps are only rated for 50w?
I thought they were rated for 150w. Is that other Memphis a 4 or 2 channel? Power ratings?
150 will work as long as your crossovers are set correctly.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif,but id be much happier to see you run only about a 100 per side.Will 150 be fine? or pushing it?
yeah. Well my amp does like 75 watts x4 at 4 so ill just watch the gains.150 will work as long as your crossovers are set correctly.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif,but id be much happier to see you run only about a 100 per side.
For sure.As another explorer owner, looking forward for the speaker install. Take many pics mang.
