The re box planner
Ive noticed there is nowhere on this thing you can count for sub or brace displacement. Im making a new box for my sub and want to know if I should add the subs volume into the over all volume. Any help would be appreciated.
Figure out your sub and bracing displacement and then subtract that from the volume the RE Calculator shows.
That will be your Net Volume.
You will have to get a program like WinISD in order to figure out how long the port should be with the new volume, because the RE Calc won't let you adjust it.
Figure out your sub and bracing displacement and then subtract that from the volume the RE Calculator shows.That will be your Net Volume.
I downloaded this winisd, but I have to make a new driver, but I dont know the specs, and re dont have them posted nether.
Just use any sub, it doesn't matter.
Put in your volume and tuning and then go set up your port.
Put in the width and height of the slot port and be sure it's for a slot port, not a round port.
Then, it will give you the port length you need.
MyFartsStink
my farts stinky they are
MyFartsStink
Oklahoma City
MyFartsStink
