THE OFFICAL 911 was a inside job thread
Was 911 an inside job?
  • Yes.
    Votes: 94 47.7%
  • No.
    Votes: 86 43.7%
  • Not sure yet but I will visit <a href="http://www.UniversalSeed.org" rel="external nofollow">http://
    Votes: 17 8.6%
  • Total voters
    197
A plane traveling at any speed is quite an impact, it blew through the entire area the plane hit at (3/4 of the way around the building) While the building was built to handle such a force, the extent of the damage to one side stressed other areas. Anytime something fails in architecture, the results are catastrophic. The minute one part failed, the weight of the building above took care of the rest of the structure. Like a domino effect, I do not think any engineer could have designed a building to handle the stress of collapsing metal/concrete 110 stores above ground level with a massive fire burning between.
Why would the gov have easier access to the building than terrorists? Either way they wouldn't come in and say "were the government we need to clear this floor for special things to go on..."
Whether terrorists or the government were to plant explosives they would probably have set something up so that they would be disguised (sp?) as construction workers or something doing work on the building...
Plus, I'm going to look at the videos that I haven't seen in a few years, but WOULDN'T THERE HAVE BEEN ANOTHER EXPLOSION RIGHT BEFORE THE COLLAPSE???
if you see the video loose change second edition, it shows like 3 different angles of the towers collapsing, and about 10 floors below where the floors are actually falling there a many different explosions.
It was made of steel reinforced CONCRETE, concrete doesn't burn...
Also, it wasn't HIT BY A 100 TON AIRLINER TRAVELING AT OVER 300MPH...
And do you not think the twin towers were built of steel reinforced contrete?
EDIT: Just for clearification, any building the size of the towers could not successfully be built strictly of steel. Metals are malable, no matter to how small of a degree. With that said, concrete is necessary, as a birttle material, to aid in the support when you're dealing with that much weight.
No one will ever know the truth, I am sure the government knows SO many things that "we the people" have absolutely no clue about. And even if we did find out that the twin towers was an inside job, wtf do we do then?
Okay, well I'm no engineer, maybe that's not relevant. Either way a massive plane hit it going very fast, that would cause a lot more damage than the fire itself. It seems the fire was just the icing on the cake.
I'll have to watch that video, I never saw any other explosions.
Ok lets ignore the pentagon, the twin towers, and flight 93.
On sept 11th at about 5:30 in the afternoon building 7 a 47 story modern steel building fell to the ground in 6.2 seconds or freefall speed. The same speed it would take a bowling ball to hit the ground if you dropped it from the top of the building.
Watch the building fall.
http://wtc7.net/videos.html
Now Its impossible that a few isolated fires made that building fall straight down at freefall speed.
Can you imagine the fire being hot enough to make the whole skeleton of the building fail at the same time.
Even if i gave you 500,000 gallons of jet fuel and gave you a week to completly soak the whole building do you think you could make it fall at freefall speed??
It defies the LAWS OF PHYSICS.
Now if you watch the manner in which building 7 was brought down you will notice that the twin towers fell in the same manner, Within 1 sec of freefall speed.
Even if the pancake theory were true, and each floor took only a half second (very unlikely) to fail the total fall time would of been around 20 seconds.
http://janedoe0911.tripod.com/BilliardBalls.html
Building 7 is the 3rd modern steel framed building in history to fall from fire, The first 2 were the twin towers. Never before or after 911 has fire made a steel building completly collapse.
so your implying that concrete doesent burn but steel does:crazy:
the steel would have to reach 3000 degrees to melt. jet fuel will burn at 1500 degreeds only if oxygen is maintained.
Yes, there was an explosion seconds before the first and second tower came down..if you watch loose change..it has some footage where a woman had her video camera on a tripod filming the towers burn..iirc, 6 seconds before the first tower starts coming down her tripod noticably shook a good amount..
as far them having access..wouldnt be very hard for a few teams to go in and plant the charges while they were clearing out the buildings on a random drill one section at a time..
also has interviews with maintainance workers and how they heard an explosion below them, while on the one of the basement levels...then moments later they heard another explosion above them..
after the mayor convieniently had everything sent the rubble (evidence) overseas to be recycled he finally let some govt orgs in to investigate (fema etc) they found molten steel on every one of the 6 main structural supports levels down in the basement level..
Thank you.
The entire events of Sept 11 are so suspicious, that the ONLY logical explaination is that it was an inside job.
I just find all this funny considering all this shit is being brought foward from 3 people that are from Canada. Arguing with people from Canada about what really happened is like racing a yugo against a Lambo. What the hell is the point anymore. Let them believe what they want to believe. I have come to the conclusion that you people just are ignorant bishes that have nothing else to do than try and stir up shit.
You are quite ignorant and stupid.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thats fine bud, but a least I am nothing compared to you as far as being ignorant and stupid. So you win that one as well. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Crown_amps
Banned
Crown_amps
British Columbia
Imtjnotu
