The DEFINITIVE Sound-Deadening Thread!!!
i can attest to that... makes a gigantic mess and scarcely works....
Oh... and...
Make sure to plant those azalea bushes when you're done talking about deadening //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
If you apply it at the proper thickness it works better than brushing anything on - since the coating is more uniform. Saves waste, and as for making a mess, I don't know what gun you use, but our pattern is quite controlled.
Just to add to the DIY er's
USE GLOVES!!!!!!
Yesterday i put in about 4 sheets of SS on each of my front doors and well i can feel my finger tips. SS tore my fingers up from pressing it with my fingers. Sounds great and also makes nice DEEP cuts into fingers.
What gun do you use?
I tried the SS gun with a decent sized air tank and couldn't get it to work for shit......but, then again, I may just be too incompetent //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Did you get the a stock or b-stock spectrum?
ANT
Got a 6 1/2hp compressor and the gun from PE... Did you remember to turn the tip PSI down to about 40? If you exceed that your pattern will go to hell in a handbasket. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Pattern? What's that? I couldn't even get it to shoot out of the gun //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Then something's wrong...
Seriously - it's like applying spraypaint when it's going properly... Only difference is there is next to no overspray. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
USE GLOVES!!!!!!
Don't be such a p|_|ssy. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Is 20 ft enough for the doors and trunk lid? I will also be using foam and liquid for the other parts.
Generally speaking, doors take 6 sqft., the rear deck takes about 10-12.
MetalMaxima
AURAL DESTROYER
MetalMaxima
The Garden State
ndnbolla
