MetalMaxima
AURAL DESTROYER
Alright, boys and girls... here is my $0.02 on the sound deadening/dampening issue. I am disgusted with the volumious responses given in which Dynamat is touted as being the greatest vibrational-stopper ever. WRONG! It's not bad, but there are many better, cheaper alternatives that will give you not as good an effect, but BETTER. I do not claim to be an expert in this category (or any for that matter), but I have done an extensive amount of research on all of these brands and have gained a great deal of information in my studies.
WHY - We deaden our cars to defeat unwanted vibrations in the trunk, door, rear deck, etc. so that our cars don't sound like $20,000 peices of tin in a windstorm. Some of us do it to kill ambient noise from the road, wind, etc. Lexus inteiors are equipped with piezo-electric devices which actually serve to cancel out the ambient frequencies between 500 - 2000hZ. While we don't have that advantage, there is ALOT we can do to stop it. A well-deadened system will have a much richer bass and midbass sound & feel since the waves will be in our interior, not stuck in the nether known as our interior panels. Another great thing about deadening our cars is that we can reduce the heat inside the cabin since the deadener acts as a resistor against the energy in ambient air.
DEFINITIONS
There are two types of sound deadening, which are as follows:
MASS LOADING - Involves adding weight to a particular panel of the vehicle to inhibit vibration/rattle. Somewhat effective in defeating ambient soundwaves, great for bass improvement. Pads and liquid deadeners work best for this application.
BARRIER LOADING - Involves adding an acoustical absorber as to absorb sound waves from ambient noise (road, engine, wind, etc.). Great for ambient noise, somewhat effective in improving midbass. Foams work best for this application.
TYPES
PADS - Asphalt pads such as Dynamat, Damplifier, Roadkill, etc. Need to be applied to metal. Look for a thick pad (>45mils) with a nice heatfoil sheild (>4mils).
FOAMS - Ensolite, rattle pad, overkill, acoustical foam, etc. Can be applied on top of plastics and metal. Works best over an asphalt pad. Look for a closed cell foam.
LIQUID - eDead V3.0, Spectrum, Sludge. Works for both mass and barrier loading. Can be applied on top of plastics and metal. Works well alone or over asphalt pads. Look for a semi-viscous putty/paste. Much easier painted than sprayed.
BRANDS
Here are a number of various companies whom produce deadeners. Many members have used many different brands. This list is in no particular order. Many of these brands are cheaper because they come factory direct, thereby eliminating the middle-man cost. Click on the brand name to link to their site.
Second Skin Audio
*This is my weapon of choice. Anthony, the owner of SS, can be reached on his cell phone at any time to answer your questions. Unrivaled customer service and frequently holds GDs on their forums.
eDead
*Highly affordable solution to deadening...but is teh ****.
Cascade Audio
*Expensive but worth every penny
Quiet Car
*No reviews available
Stinger Roadkill
*Very expensive, very effective
B-Quiet
*Another good alternative
Raam Mat
*Arguably the best mat available, esp. when layered
Brown Bread
*Good, but better can be found.
Dynamat
*Good, but not worth the price at all.
Fatmat
Peel n' Seal
*Used in the roofing industry. Stinks, doesn't work well.
SURFACE PREPARATION
As with paints, you too must take measures to ensure proper adhesion of your deadener. A highly regarded practice is to first wipe the area down thoroughly with a degreaser to remove any oils that might lie on the surface. This is to be followed with a second wipe down of acentone to make sure the surface is bone dry. Make sure NOT to cut corners on this step!!!
APPLICATION
ASPHALT MAT & FOAMS
(1) Using a heatgun, warm the surface of the adhesive side until it begins to tack.
(2) Firmly press your mat into the desired spot.
(3) Thoroughly roll over the mat with a heavy-duty roller. I'd recommend a rubber roller since it will contour a bit better to unlevel planes.
(4) For foams without the benifit of OEM adhesive, I recommed 3M Super 77 Spray Glue.
LIQUIDS
(1) DO NOT SPRAY!!!
(2) Use a quality 2" horse-hair brush and simply paint on.
HOW-TO
Proper Door & Trunk Sound-Deadening & You
Upgrade the BIG THREE (worth adding)
...got anything to add? ADD IT! Let's make this a good resource for people to come to with their deadening questions!
DEFINITIONS
TYPES
BRANDS
Second Skin Audio
eDead
Cascade Audio
Quiet Car
Stinger Roadkill
B-Quiet
Raam Mat
Brown Bread
Dynamat
Fatmat
Peel n' Seal
SURFACE PREPARATION
APPLICATION
ASPHALT MAT & FOAMS
LIQUIDS
(1) DO NOT SPRAY!!!
HOW-TO
