::TESTED:: Audiopipe AP30001D
yea but take all them out and whatch ur score go up about 2-5 tenths //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Actually to the volt meter it was the same so I dont see how my score would be better. I guess I have no loss due to 4 runs of positive and 4 runs of ground 2 of each per amp.
I agree, when it comes to competing, that is fine as you want every 1/10th you can get. As for a loud as F u c k daily driver fusing is the best option. Just add an extra run of 1/0 to make up for the loss. Thats what i did. Its a hell of alot cheaper adding 1 extra run of 1/0 then replacing vehicle,equipment or both.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I may be new on "THIS" forum, but not on others, and I couldn't agree anymore with what you said:). I just bought 2, and hope to hell that there at least "decent" Im not looking for quality like my VLX400/USA800 amps, but something to hold me over till I can afford 2 DAT2500.1's or 2 SAZ3500's or something. And with all i've been reading on the internetz, they should be just fine.
pics? //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
Can I wire it to 1 ohm and be fine?
as previously said, the box matters a ton! I ran one of these with the same electrical at 1 ohm in two different boxes, one box worked, one didnt. if youre unsure on how to do a proper box, you could always find someone on these forums that does, or just up it to 2 ohms. gonna be louder of course at 1 ohm though
Well I have a D2 sub so I cant wire it to 2 ohm. its either 1 ohm or 4 ohm. I have a c&d battery in the back and I dont play it full tilt often. Hopefully I have a high imp rise.
dam bro, with a stock alt and only that batt, good luck on 1 ohm even with the proper box //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I put it on 1 ohm and it doesnt go into protect. I put my pos and neg speakers wires in seperate terminal things. I dont know if I should put them side by side or keep them the way they are. It doesnt hit hard at all, all my settings are messed up. What should I have the LFP, Subsonic, freq, etc. at? Im tuned to 32hz.
vehementSPL
vehementSPL
indianapolis
Wingman0121
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
