::TESTED:: Audiopipe AP30001D
you can wire it to 1 ohm bridged. will not operate any lower it will go into protect. to battle the imp rise you will have to test build test... it's all in the sub enclosure.
Yes, the sub must be playing. Impedance is basically the dynamic resistance... so it needs da powah!
Use the DMM for AC Volts on speaker terminals + a clamp meter for AC current, on one of the main the speaker wires. Play a tone just under full tilt. Record the values simultaneously (digicam helps).
If you multiply the values (V*A), you get power.
If you divide the values (V/A), you get impedance.
dont have a clamp meter. Amp should be coming tomorrow. All i have is 4 guage, how will it do for temporary? Maybe I can fit 2 runs into the amp inputs?
i really hope this 1800.1D will be as leet as it says it is @ 1 0hm. and hopefully not be heating up.
does anyone know the size fuses it has on it?
whether its like, 3 x 30 amp or whatever?
Think the AP D class use inline fusing. I know the 3000 does.
well... i looked up the aqx-3500.1d and the fuse rating was 200A now... my ap30001D has 300A worth of fusing seems like the 3500 shoul dhave more? unless it was a typeo
They include a 200 amp fuse with the 3500 and 3000 watt amps. If you dont feel that is enough just replace it with a 300 amp fuse.
vehementSPL
vehementSPL
indianapolis
Wingman0121
