::TESTED:: Audiopipe AP30001D
**** I wish I had the silver one that was 1 ohm stable.
this amp is 1ohm stable? 1500w X2 @ 1ohm. I dont get what your saying. Are you wishing it was 1 0hm Bridged stable? WTF is the difference, if you need 1ohm, just dont run it bridged.......
Well i can run it kinda loud with some bump, but when I try to crank it, it goes into protect till I turn it down. It is guranteed if I get better electrical that it will stay in 1 ohm? or is it just luck
These are not exactly what most would consider 'overbuilt' amps. If you run it under manufacturer recommendations you will be shortening its life span. Run the amp the way it is supposed to be run or your going to blow it. The shit is not really that complicated.
Bobby, upgrade your big 3, get a high output alt and get that amp some 1/0! It never went into protect the way i had it set up. You def need to make sure you have a good ground and get that thing the correct cables otherwise you're gonna strain it. Do it right, or dont do it at all. Good luck.
I do have 1/0 i just bought it today and installed. I def. wont be spending the money for a HO alt. I can do the big 3 when I get my hands on some more 1/0 (i have lots of 4guage right now). And maybe I can pick up another c&d battery for cheap but I doubt adding another battery will make it work in 1 ohm.
Ill wire it to 1500w tomorrow.
what is ur voltage drop? make sure to beef up the grounds under the hood really well.
the silver 30001 was NEVER 1ohm bridgable "rated".
i am a audiopipe dealer and have alot of experience with these amps if you need something answered just pm me...
vehementSPL
vehementSPL
indianapolis
Wingman0121
