kicker06
Umm, I don't pay for food
After Searching, I have found that there only are a limited number of threads on this subwoofer and any one the Standard series drivers, so I decided to make this thread.
I would like to learn about this woofer and the other in it's line and hear what you have to say about them. I am looking at buying a 12" TC-3000 and want to know what everyone thinks.
Add pictures and everything and anything you want to add about the driver. Comments, pictures, whatever is welcome.
Ill Add some things to get this thread started:
• Triple stacked ¾" tall ferrite magnets
• 250oz motor structure
• xmax of 30mm (one way linear travel)
• Dual (10"/8.5") poly-cotton spiders with intergraded woven leads (12",15"/10")
• Extra spacing in-between spiders for lateral stability
• Extra clearance under the suspension for dynamic high excursions
• Detachable cast aluminum basket with high gloss power coating
• 3" diameter, quad 1.4Ω/dual 3Ω aluminum voice coils with eight total layers (12",15"/10")
• 1000 watts sustained (3000 watts dynamic)
• High quality thermal flexible epoxies to ensure longevity
• Rigid lightweight brushed aluminum cone
• Vented flared pole piece
• Copper shorting ring
• Tall durable rubber surround allows for extreme excursion
• Optional competition package for even higher sensitivity and output.
• Dressed in a rubber magnet boot and gasket
• Hand built in our San Diego, CA factory
12" TC-3000 QVC
Qts 0.303
Qes 0.325
Qms 4.38
Fs 24hz
Res 5.6Ω
Ls 8.85mH
Lp 19.25mH
Rp 25.95Ω
Dia 254mm
Vas 50.40l
mms 301g
cms 140mm/N
bl 29T*m
Spl 86.0dB
Again, I made this thread because I want to know everything I can about this Driver and I think this is a good way of doing it.
12" TC-3000 QVC
Qts 0.303
Qes 0.325
Qms 4.38
Fs 24hz
Res 5.6Ω
Ls 8.85mH
Lp 19.25mH
Rp 25.95Ω
Dia 254mm
Vas 50.40l
mms 301g
cms 140mm/N
bl 29T*m
Spl 86.0dB
