Taramps "50k" High Voltage .5 ohm
A_Contraptions
NC
taramps t-50kw
The high voltage modules are amplifiers that use a large number of batteries connected in series (positive battery on the negative otherwise, instead of positive to positive, negative to negative) and provides two advantages, the high efficiency in energy consumption batteries and consequently can play longer than 12v amp; exelente and cost-effective to use a lot of high high-power speakers.
The Amplifier Module Taramps T50.0KW has power 50000w rms. The 0.5 ohm model sends this power to 0.5 ohm with 19 batteries connected in series (each battery has to be 120 amperes or more). The 1 ohm model sends this power at 1 ohm with 27 batteries connected in series (each battery has to be 120 amperes or more). It has frequency response of 5 Hz to 15kHz, great in use with speakers for systems automotive sound external.
All this power is controlled by the built-in crossover with cutting options HPF and LPF, and gain adjustment.
The Taramps T50 also features several technologies to facilitate its use and increase the safety of car audio:
- Internal ventilaçação System, which enables the use of several hours at optimal performance;
- Led's in sound distortion indicators (to help the user to not burn the speakers), protection in amplifier (against short, etc.) and operational expenses .
The T50.0Kw amplifier module is perfect for anyone who wants a high-power and technology system, without sacrificing sound quality and convenience of use, and has all the quality of the largest factory of automotive amplifiers Brazil!
It is recommended to use a source or charger and a high-voltage voltmeter (Taramps VTR1500) for energy maintenance on the batteries.
see pics for condition
Power of Taramps T 50.0 KW models:
0.5 ohm Model:
Channel number - 01
Max Power @ 240 VDC. - 0.5 OHM - 50,000 WRMS
Max Power @ 240 VDC. - 1 OHMS- 28,584 WRMS
Power Minimum voltage - 100VDC
Power supply Maximum - 300VDC
Consumption Home - 140mA
Maximal Music @ 0.5 OHM - 120 Amp.
Maximal sinewave @ 0.5 OHM (100 Hz) - 240 Amp.
500 + shipp
References- Jeffhulbert50
Who the hell has the electrical to run this ****? Where the hell do you put 30 batteries?
I have 28 now. I had 32 in my last build //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
If Jeff's price goes much lower, I'm going to buy this just for shits and giggles
A_Contraptions
A_Contraptions
NC
Nutdawg651
