Hi,
I have a 2003 Acura MDX with a factory bose system that have a low-level output from the HU to the factory amp. I decided to use one pair of RCA and cut off one end of it to tap into the low signal from the factory HU to factory AMP. Here is the wiring diagram of the factory AMP:
Let say I want to tap into the Audio Unit front set:
a) Do i tap into Audio unit right front + (cavity 21 on the connector above) into the R of the RCA and Audio unit right front - (cavity 8) into the L of the RCA?
OR
b) tap into Audio unit right + (cavity 21) into R of the RCA and Audio Unit left front + (cavity 23) into the L of the RCA?
I hope I've made my question clear. I've ran all of the wires already, just wanted to make sure before I start tapping into the factory connector. Thanks!
OR
