Tang band sub In BT build
  • 2
SlugButter
CarAudio.com VIP
4,664
2,147
arizona
Not really car audio, but I thought I’d post it. Using a tang band 5.25 inch sub and a small 2.1 amplifier. 50 watts to the sub and 25 to the two 4 inch speakers. I used some 12 dollar Pyle speakers I had lying around. Running the amp on 24 volts. The sub has around 9 mm of excursion. Moving some decent air with this little beast.
Finished the garage stereo. Cut up a kick plate off an old door to cover the top and back of the amp. I found that I don’t have the tools to cut a square hole in the middle of metal, which is why the digital screen is in the wood Instead of the metal panel. I also found that the remote is a piece of crap with maybe 6 feet reach, so I installed a volume knob on top, which wasn’t in the original plan.
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
  • Locked
The Orion Concept 97.2 was the worlds first stand alone digital 30 band 2 channel equalizer. The Orion Concept 97.2 processes all the equalization...
201
Great news, my ground connection was loose and I replaced it and it sounds just like before. Thank you for the help!
238
SlugButter
CarAudio.com VIP
SlugButter
arizona
SlugButter
SPLBassJunkie
    May 21, 2024
    May 20, 2024
