DDSC
Wang-aholic
(Speed of sound in inches/second) / (4*Frequency in hz) = wavelength in inches
Transmission line enclosures do not always need to have the line area equal to the cone area nor does it always need to exceed it. This can work but is often not necessary. In order to find out how much line area you need, you need to consider the resistance factor of the driver, the shape function of the line (line taper and line frequency), the Sd, and the Re/(BL^2) product. That will give you an idea of how much line area would be optimal for the driver. Changing the line taper and line area will affect the frequency response and low frequency extension of the system. If the line area is too small for the mounting depth of the driver, it's possible to add a compression chamber for the speaker to fit.
Transmission line enclosures don't have to be as large as people think. I fit one in smaller dimensions than I fit a 2.2 cube ported enclosure. It had better efficiency; low frequency extension; power handling (mechanical power handling increased around 15-25hz); and transient response.
They are not going to be the best for getting loud at a single frequency but will offer a very musical and very efficient enclosure with a low end that is effortless and full. That is if the design is well implemented for the driver and vehicle.
Will it move gobbs of air
