System Refuses to Play Music...Beginner Requesting Help!
id say wire a batt instead of a cap, but i agree with olegni about the voltage and that it isnt necesairy if theres no significant drop. u could try bypassing ur eq and go straight from the hu to the amps with ur rca's and see if that fixes it.
Hey!
Just wanted to get back with an update! I dove into it this weekend..checked the EQ first. Plugged everything back into the hu..and voila..I had sound again (not nearly as crisp and clean as with the eq..but sound nonetheless). When I took the EQ out I heard something rattle when I flipped it over to inspect it, my assumption is..this is not supposed to be rattling.
I plan to exchange it for a new unit..since I've heard great reviews on this EQ for an "entry level basshead" model.
I've also attached some pictures, as promised, of my system.
I cannot tell you how much I appreciate all of the help. Any further input on what could have gone wrong would be GREATLY appreciated!
If you took out the eq and have sound again, that sounds like it's the problem. I would still take out the cap. Is that a soundstream EQ? From what I've heard, you should go with an AudioControl EQ, unless you can only exchange your broken one for the same one. How many bands does your kenwood eq have?
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
401
733
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
D2VP
D2VP
Chicago,IL
fly_marlin
    Jun 18, 2024
Dan Medina
    Jun 17, 2024
