System Progress -- 56k watch out!
sundownz
Pro Seller
Supporting Vendor
* Front door before deadening
* Front door after deadening. Edead V1SE(2) mat used for inner and outer door sheet metal. Outer sheet metal has 2 layers on all, and 4 layers directly behind the speaker with Edead V4 Teklite on top to absord midrange reflecction. Edead V4 used again to prevent the metal rods from rattling.
* Rear area with interior removed
* Edead V3 liquid deadener applied, Edead V1SE(2) mat deadening will be applied on top of this. I bought the V3 with no real planned use for it so I'm slopping it on the floor of the Civic just to use it for something //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
* Starting to deaden inside side cavity, these cavities will be filled with expanding foam after the outter sheet metal has been fully deadened. Peel & Seal is being used for the outter skin deadening.
* Rear hatch door deadening started
The roof will be deadened using Second Skin Damplifier. I'm ordering that in the next few days. It's my favorite overall deadener but a little too expensive for me to do my whole car with.
Thats it so far... I have alot more work to do so pics will be added as I move along. This will be the demo vehicle for Sundown Audio when it's ready. I intend to supercharge it so I can actually drive regular speed with the extra weight from deadening and the upcoming system =)
looks pretty good so far, good job
what's going in the car?
Planned Equipment:
JVC KD-AR8500 Head Unit
Rockford Fosgate 3Sixty.2
DLS Iridium 6" and 1" tweeter in kicks
Aurum Cantus 6.5" Midbass
2x Sundown Audio SAX-100.4 on the fronts
2x SI Mag D2 12" Woofers (ported)
2x Sundown Audio SAZ-1500D
Duralast Gold 625 CA Battery Under Hood
Duralast 1000 CA Battery in the Back (already had this laying around)
* Possibly a third battery, some sort of deep cycle
* HO Alternator Coming later as well
Knukoncepts 1/0 wiring from front battery to rear
4 gauge or 1/0 under-hood grounds / alt / starter wiring
Tara Labs Speaker Wire and RCA Cables
It's got a LONG way to go... the only "system" in the car right now is the JVC Head Unit and some Audax 5.25" Coaxials to make some sound so I can actually drive and not go insane //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I already have most of the equipment, it's just a matter of installation at this point.
Wow you deadened the shit out of those doors. I can tell your going to be very happy and have almost no road noise.
I'm a big fan of deadening. Wait until you see the craziness when I fill in those side cavities with expanding foam //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I still have to do the other door as well... I'm kind of attacking it at all angles at once so if I get bored of deadening something I can do another part to keep myself sane.
The duralast batteries are the ones they sell at Autozone right?
Is the Gold (1000CA) battery a deep cycle?
I don't believe any of them are deep cycle. I've got two "regular" batteries and may or may not add a deep cycle to the mix depending on how it works out for me.
not to be a d!ck but Spectrum is better
For that matter I think that Edead V3 is more like Sludge. It's incredibly thick stuff. Either way, it doesn't matter... I'm putting mat on top of it so sufficient deadening will be there. Anyway, I already had the V3 in my basement so I threw it in there //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
CBFryman2
vegang
vegang
