bernouski
So far I've run into numerous issues on my DIY Subwoofer install.
First I skipped out on the remote wire giving me no power, solved that. Then signal has been failing to reach the HU up until this point. I messed with running RCAs from front to back with no luck, and these are quality RCA's.
I've also messed with the Headunit sound settings from Rear/Rear from Sub W./Sub W. to Sub W./Rear with no such luck. I then installed what I thought was a LOC but has also failed to work, I'll post pictures of that now.
I come here asking if what is in the pictures is actually a LOC or not and if it is not then I'm running to Sonic Electronix this second to spend $10 on a Line Output Converter.
