system in the winter?
should i put my system in.
  • wait till spring cause the cold might fu(k something up
    Votes: 1 3.4%
  • everything will be cool and put it in
    Votes: 28 96.6%
  • Total voters
    29
talon2nr7588
is it ok to keep your subs and amps in the car when winter comes? it's starting to get cold here and i haven't even put in my system and i decided to wait till spring again since i thought the subs would mess up because of the cold. here the lowest it'll get is like 0 degrees farenheit. but then i thought that maybe it would be okay because that way the amps won't get hot ata ll and it would play even better. so should i wait till spring or go all out?
When I posted, the poll was not yet showing //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
BTW...it gets very cold here aswell...had a stereo in my car for the past 8 or so years and have yet to have anything become damaged as a result of the winter months.
you can't run your system in the winter cause your subs will freeze up and if you run power to them, the cone won't move and that will end up frying your voice coils, and cause your amp to produce more wattage then it is suppose to, basically causing it to clip and could fry your amp as well. i live in michigan. i learned the hard way //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I would have never guessed it gets cold in "The Hollow Depths of Hell" but i've been wrong before. lol
Same here .. Northern MN sees weeks of sub zero temps., Last year weeks of Sub 20-30 below temps.. My sub always loosened up before my car did anyways:uhoh: .. Just dont plan on playing any tones or kick drums for a good 1/2 or so //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Where do you live anyways and how cold does it get?? If your talking cold as in .. say anything above zero you need a kick in the nuts //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
talon2nr7588
talon2nr7588
Indiana
talon2nr7588
AJ (ACE)
    Jun 28, 2026
